Holley tuning help please
Tigged and ground down. We'll see how they work.
if you dont get your ign timing correct you will destroy the engine. 60 deg ,,,,,don't do it !!!!!!!!!!!!!
I am in need of a tuning guide or web link for Holley Double Pump tuning. I need to understand the circuits a little better to diagnose my problems.
http://www.amazon.com/Holly-Carburetor-Handbook-4150-Hp473/dp/0895860473
krowbar, are you still running 60 total timing?
Waaayyyy too much timing. Remember, timing first, then carb tuning.
If you are doing both you're chasing your tail.
every .015" reduction in the slot length reduces mech advance 1 distributor degree (2 crank degrees).
Dimensions for Mopar distributor slots, in DISTRIBUTOR degrees
Modifying advance slots
degrees / slot size
6.............. .340
7............... .355
8............... .375
9............... .390
10.............. .405
11.5 .......... .420
12.............. .435
13.............. .445
14.............. .460
15.............. .475
16.............. .490
17.............. .505
18.............. .520
