ryanjroberts
Hey guys,
I appreciate your time in reading this. I have a '71 Road Runner that lost its brake lights. I don't drive it that often, but was backing her in the garage and my son said that there were no brake lights. I figured to start simple...the brake switch off the pedal has continuity and voltage, while I was under there I noticed the fuse was blown for the "stop light". Hmm, replaced the blown fuse with a new 15 amp fuse expecting it to blow but nothing happened. Fuses don"t just blow without reason I know, but the new fuse stayed intact. Everything seems good but blinkers are slow... marker lights and tail lights all work, 4 ways work...all other lights work, but brake lights don't. That's it. Also, I noticed if I pull on the lights, the left green blinker light in the dash console stays lit, even not having it "clicked" to the left. Haven't had the lights pulled in years but I don"t remember that....
In reading, all signs point to the turn signal switch...as voltage passes through that before the brake lights? My question is are you guys do you agree I should replace that and go from there, and also where the heck is it at? I know it is buried somewhere under the ash tray area.......
Thanks a lot for any info!
Best Regards,
Ryan
.............Please do not post email addresses here - it is against site rules, and for your protection.
Best Regards,
Ryan
aboard Ryan!
