combatsp
- 10:45 PM
- May 16, 2011
- South Williamsport, PA
I have a 1968 Charger 440 I am preparing to sell. I hooked up a new MSD6al2 ignition with MSD distributor. I fired the car up and it ran perfectly. When I turned the key to the off position the car continued to run as if I never turned the key off. I read that there can be bleed back into the system that will cause this. I installed a 4 prong ballast resistor as directed by the instructions and it still will not turn off. I had to remove the negative battery cable to stop the car from running.
I noticed that the battery cables throw sparks when I remove them even if the car is off. Never noticed that before. I checked my wiring job versus the instructions and don't see any problems but still not ruling my screw up out. Could it be the started relay or ignition switch? Thanks.
