383 HP Question
Beavis
2:45 AM
Berkshires
i think im buying a 69 383 hp block and caps out of an A body. it has no crank. will this be hard to find ?
is the crank any different on a 69 383 HP A body 4 speed car then say a b body auto?
You are buying a 383 block possibly stamped HP. A-body, B-body, C-body, E-body, makes no difference, it is a 383 block. If it is just a block, the HP is just a stamping, nothing more. The only difference between the auto vs. standard crank is the pilot bushing area. the Auto crank might not be drilled for the pilot bushing.
yes, the A body block has two ears for a different motor mount.
If you buy it would you please post a picture of the block? Just interested in the mounting locations mentioned by monaco66coupe.
also,
my 68' 383 A body is numbers matching, but Chrysler didn't stamp those engines HP to my knowledge. So if it is stamped and a 69, look for a VIN to see if it isn't really a B body. I'll try to get a picture of mine and post the mounting.
383 A engine mounts
here are pictures of the 383 A engine, and All other 383 engines. A engine is first, and the Car. 27 sept 2015 383 A and  B engine mounts 006.JPG27 sept 2015 383 A and  B engine mounts 003.JPG27 sept 2015 383 A and  B engine mounts 002.JPG26aug 14 GTS is home 015.JPG
In the first picture the exhaust bolt configuration at #1 looks different or is it just the picture?
yes it's just an extra from the rear where the exhaust manifold is deeper. normally a short stud and nut.
