Fuel Line routing problem-70 RR
JMCFAN
12:48 PM
Corrales, NM
OK..70 RR 383 with Holley carb. I opted to go with 3/8 fuel lines and return ( with VS). So the lines I purchased are not lining up... duh...
Now I can buy the fuel pump to VS line for 6pak or Carter application that I believe will work fine. Does anyone have pic of routing from VS to carb.... what a drag...
Just snapped this pic for you hope it helps, I have the Carter pump.
