FOR SALE 71 charger grilles
1970 Roadrunner
6:46 AM
ozark, Mo.
Feedback: 25 / 0 / 0
Have a set of 71 Charger restored grilles. Repairs made, and pictured. all back teets there or replaced, mounting posts all there. Some have been replaced. All repainted and beautiful. I do the 68-69 Charger grilles, 116 so far so these will definitely pass inspection. No disappointments. $800 plus the ride.
Nope. 70 is all by itself. totally different. One large piece of plastic with metal backed plastic hide-away doors.
What modifications have to be made to install 71's on a 74?
no clue. Never had a set of 74's in my hand to compare how they mount up, and their dimension differences if any.
I believe they mount up the same, I don't have them in front of me but I'm purity sure I had 71 grilles on my 74 at one point all I have is a few hideaway setups and hard mount 74's laying around I sold my 72 hard mounts a while back
regarding 73 and 74 grill sections. These models have the rubber insert between the grill and headlights. Installing the early 71/72 sections may require one of two options. reuse the rubber or use 71/71 bumper mounting brackets to frame rails. This will move the bumper back 1 inch. Thus eliminate both grill inserts and rubber between bumper and hood. Good luck.....
These grill are very hard to find in good condition. Nice restoration. What tools or glue do you use to repair the sections. Eastman sell equipment and material. Not use if the product will work on the 70's plastic
71 grilles will install in 73/74 with minor mods. IIRC not all the screws line up. Two are the same, two can be drilled and two can be left out. Had 71 grilles on my 74. The rubber around the headlights or around the bumper does not come into play, nor do the bumper mounts.
Have both sides of the rubber inserts to go with these. Just haven't cleaned them up or restored them . Have no use for them so I can throw them in with the grilles.
