67 Charger Fender Tag Help
RR Fan Dan
If it ain’t broke, fix it till it is.
9:37 PM
Virginia Chesapeake Bay
I posted this in another thread but since I wasn’t the OP I didn’t want to hijack his thread. The Charger below is for sale and I inquired about it and the owner sent me the fender tag. Can I get some help decoding please. Thanks
Well you picked the most expensive years (for the most part). Some nice first gen chargers for around 20k. Here is a one that has a 383 (very nice motor)and factory ac. (Very desirable). Nice driver. Looks like what you’re looking for. Nice driver and you can tinker with it. Needs a few things like headlight doors and ac hooked up but cosmetically it doesn’t look like it needs much of anything. This is just one example of what you can get for 20k in a b body. I always loved the interior of the first gen chargers. The instrument cluster is gorgeous as well as the seats. But my point is there are a lot of nice B Bodies between $20-$30k if you expand your search beyond 68-70. Not just chargers either.
Vehicle Description​
$20,000
Here’s a very nice 1967 Dodge Charger survivor with the 325HP 383 Magnum V8 4-barrel. The 54k miles on the odometer rolled over once as the original interior is in amazing condition without any tears or rips. There is one crack down the center of the dash and otherwise, she’s in great shape. The motor was rebuilt and does not have any leaks and the freeze plugs still look like new. It’s been repainted the original WW1 white that’s a good driver quality condition and has the black interior. It is a power steering and original AC car with every component still intact but as you can see under the hood it is not connected as with the heater hoses.
This is one of my personal vehicles and I’ve gone through and replaced the valve cover gaskets, transmission fluid/filter, rear diff flush and new seals, new tires 500 miles ago, all new shocks all around, install all new wheel bearings, u-joints, rebuilt the brakes including new hoses and wheel cylinders, strut rod bushings, etc. She fires right up, gets up and runs out smoothly and is ready to cruise.
The headlights work but the doors are non-functioning as with some dash gauges. I did put power to the doors, lubricated them and they fully function so it has to be the relays. May have replaced shortly. The current pricing reflects and will start to check the motors and relays and replace if necessary. Hagerty shows fair condition (#4) at $19k and good condition (#3) at $32k so this one is priced right.
Walkaround and undercarriage videos included and cold start with driving videos to follow. Let me know if you have any questions or would like to see additional areas.
#brunoclassics
406-561-3441
For Sale: 1967 Dodge Charger in Missoula, Montana
View attachment 1878681View attachment 1878683View attachment 1878684View attachment 1878685View attachment 1878686View attachment 1878687
May be a little off but most is correct. Hard to get the numbers to line up on the decoder. lol this is my 3rd time editing this because I saw some issues.. This should be very close. Items in red are questionable.
CAR: Dodge Charger 2 Door Sports Hardtop
ENGINE: 383cid 4-bbl HP V8
TRANSMISSION: 3-Speed Automatic
TIRES: 7.75 x 14 WSW
MODEL YEAR: 1967
BUILD DATE: March 21.
AXLE: 3.23 Rear Axle Ratio
INTERIOR: Sport Trim Grade
PAINT: White (Dodge, Plymouth), Persian White (Chrysler, Imperial).
OTHER: Mauve Metallic (Dodge, Plymouth), Mauve Mist Metallic (Chrysler), Dust Pink Metallic (Imperial) Upper Door Frame Color. Stripe Deleted.
MOLDINGS:
ABC OPTIONS:
A1: 26in Radiator
R1: AM Radio
S1: Air Conditioning
X1: Tinted Glass (all)
abc OPTIONS:
a6: Console
b4: Bucket Seats
g0: Unknown Option
h7: Fender or Hood Mounted Turn Signal Indicators
j4: Moulding - Body Sill Narrow
MODEL YEAR: 1967
INTERIOR: Sport Trim Grade, Vinyl Bucket Seats. Black Interior.
MOLDINGS:
ABC OPTIONS:
A1: 26in Radiator
Q1: Unknown Option
R1: AM Radio
abc OPTIONS:
b4: Bucket Seats
g0: Unknown Option
There's issue with the interior color. The part about the Mauve door frame upper
And looks like a B21 date.
a5: Buddy Seat
b4: Front Bucket Seats
g0:chrome beltline moldings
h7: fender mounted turn signals
j4: body sill moldings
A1: 26 inch radiator
R1: 2 watt am radio
S1: factory a/c
X1: tinted glass
A4: 3:23 gears
TRM: Sport Interior, vinyl, Black
PNT: White
U6: Black upper door frame colour.
SB: Black roof stripe
XP29: Charger
62: 383 4 bbl
5: automatic transmission
43: 14 inch tires, 7.75 width
5: spare tire size
B21: November, 21, 1966
The last numbers are the shipping order number.
Source: Source Guide
