Mike Gaines
- 3:52 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I do not have an air/fuel sensor gauge in my car to read A/F ratio after a run. I can't put it into neutral (reverse valve body won't allow me to get to neutral without going thru 2nd and 1st at 120mph, lol) after going thru the lights to correctly read the plugs.
What is my best alternative, if any, to get plug reading.
Summit Tech said to merely run it up to 6000 in first, click it out of first gear into neutral, shut if off and coast to a stop to read the plugs...but I dont think this is the same as a wide open run in high gear...
I have no idea if I should go "leaner" or "richer" with my jetting...is it just trial and error going up a little or down a little and see what happens with ET or MPH ?
What do you guys do...to find the best jetting
