FOR SALE 1966 Coronet 4-Door Sedan
How about the passenger side blinker unit on the front?
It is not broken however I don't know how much of the reflective coating is still there. I will take a look and snap a pic tomorrow. PM me your email address and I'll send you a picture or three.
2D and 4D should both use 9" arm rests, except "500" 2D which uses 13".
Thank you for the info. I have always had 440 and 500 model coronets so my knowledge of the sedans is limited.
Do you have that vent/defrost terminals that send the air to the windshield, both sides? In fact, I need them for my '66 Charger, I think they are the same as Coronet...
thanks!
Hi,
Sorry, I must have missed your post. I have quite a few sets of vents however they all have at least one partially broken tab. Most of the tabs were damaged upon installation at the factory. There are several options to repair them however. PM me if you are interested in a set either repaired or un-repaired.
I have some very nice original duct work also.
Thank you,
Jeremiah
Update:
Both Fenders SOLD
Hood SOLD
Trunk Lid SOLD
Passenger turn signal housing SOLD
Grille SOLD
Sail Panel Chrome SOLD
Thanks to everyone for their patience on pictures, etc.
Update:
Passenger turn signal housing: back on the market
Trunk Lid : back on the market
Driver Fender : Rust free from a different car
Hood : Rust free from a different car
Slashing prices!!!!!! Everything must go, need room for more parts and cars!
1) Driver rear 1/4 panel, perfect wheel arch - you tell me where you want it cut - $225
2) Passenger rear 1/4 panel, perfect wheel arch - you tell me where you want it cut - $225
3) Rust and Dent Free Trunk Lid - $150
4) Rust free driver fender - very light cosmetic damage - $150
5) Stainless windshield molding - no damage, needs to be polished - $65
6) Stainless back glass molding - no damage, needs to be polished - $65
7) Rear back light (glass) + gasket - no scratches, chips or delamination - $175 ( as far as I know these are not reproduced )
8) Complete small block front accessory package including alternator, brackets, pulleys, fan and bolts, unmolested - $115
9) Original small block radiator, I will get the tank number - very nice, can pressure test if you are interested - SOLD
10) Small block, non A/C front wiring harness (with light wiring, etc), complete and uncut, very nice and not UV damaged - $75
11) Non-A/C Dash cluster, chrome plating deteriorated, needles sun-faded, radio opening un-cut, circuit board pins very nice - $200
12) Rust free Driver and Passenger fore/aft fender splash shields with hardware, clips and flaps - $50
13) Rust free doors, complete, your choice - $75, I will make you a deal on more than one!
14) Column shift steering column w/ steering wheel, 66 only part, some surface rust that will clean up, 100% intact with nice feeling original turn signal switch - SOLD
15) Manual steering box, nice condition, not road tested, consider it a core - $125 I can send this to firm feel for you and save you shipping $ if you are not in the NW.
16) Small block 727 TF (I think, I'll re-check trans model) kick-down/throttle linkage, with original springs and clips - $60
17) Factory horns with mounting bolts - Failed bench test, cores only - $20
18) Nice original heater box complete with controls/cables - $150
19) Front turn signal switch housings - excellent sockets - $40 for the pair
20) Nice uncut dash frame, will clean up nice (correct mounting screws included) - $125
21) Wiper Arms -bright - Nice condition - $50
22) Wiper motor - decent core - plastic switch plate - $50
22) Wiper motor linkage w/ pivots - will need reconditioning - $50
23) V-8 K frame - nice - $75
24) .890 torsion bars - nice w/ no rust or abrasions - $100
25) Any front suspension parts - make me a reasonable offer!
26) Sedan headliner bows - nice, not rusty - $75
27) Metal glove box door with screws and hinges - $40
28) Complete 71k mile 273/auto carb to oil pan fan to tail shaft. Very original tin, etc. $250, *local p/up only unless you have lost your mind and want to pay shipping on this one*
29) Complete dash wiring harness, non-A/C, uncut - $150
30) Ash tray w/ slider and h/w - $35
31) Factory painted, non-chromed rear view mirror w/ hardware - $25
J, I would be interested in the Fender Splash Shields, are they the same for the 2 door? Do you still have them? Also, looking for a good Black Steering Wheel, if you have one?? Also, will need a Front Bumper if a good one shows. Got a 66 Coronet 500.
B,
Do you have the grille?
I have quite a few grille setups, all drivers with some amount of dings and dents. PM me if that's what you are after!
B,
PM returned!
Hey I heard the 66 coronet has the same rear frame rails as the 68 charger. do you still have them? I would be interested in the whole frame rail assembly off thw back of the car. do you still have it?
Yes I do and you are just in time. Someone just bought the front clip. PM me and I'll give you my contact info.
Thank you,
Jeremiah
Fender tag
Curious, do you have a fender tag for a 1968 Dodge Charger 383 4 barrel car? Mine was not on it when i bought it! Car was originally from Michigan and would love to have the original fender tag. Charger was original with the 383 4 barrel, Bucket seats, center shift console, Vinyl top, and the burgandy factory color. Just curious if you have one and if you would sell it? Thanks
I am looking for a crank pulley for a early pre 1970 non power steering or a/c 273/318. It measures 1 9/16'' deep.PM me if you have and price.
Thanks for checking in, I'll be in touch if I have one. We usually try not to break up pulley sets but maybe I have something that will work for you.
Sorry I have not seen that one. If you email me the SO from the car will it be the same on a tag? I have access to two 68 Charger, one of which I have yet to check the tag on.
Sorry, I'm out of them until we find another parts car. Maybe in a month or so if things slow down at work.
Thank you for checking and I'll keep you in mind if one comes up.
Jeremiah
Thanks. I really appreciate it. It is the last thing I need for my coronet and they are kind of hard to come by.
