whats your thoughts on this cam selection?
jakepup
4:48 PM
south dakota
440 bored and stroked to 493
84cc edelbrock rpm cnc ported heads
icon 9:1 pistons
bds 871 with 2x 750 quickfuels
power brakes
all run on e 85 in a 70 charger weighing 3900lbs and dana w 3:54 gears
wondering if the cam recommended here is a good "street/strip cam"
duration@ .050 int 240 exh 244
sep 112
lift 556
any thoughts??
no, i just dont want to loose if a rice burner with a turbo pulls up next to me
You probably still would if the driver is good. We have 1000HP front wheel drive Honda's around here.
With all the weight up front those ricers move.
I'm going with 16 wide rear tires and only abut 700HP........I may be able to give some of them a run.
Look at the Comp Xtreme lift cams
I went with the COMP XE285HL 241/247@.050 110LSA, 440- video below right after build
[video]http://camshaftsounds.com/cam-video/comp-xe285hl-241247-050-110lsa-440/[/video]
I am .060 grind over with and Edelbrock top end kit, no blower.
what mufflers rocketman?
I wouldn't think you would need much of a cam with the blower.
