63 ply back seat install
KyleN
11:09 AM
ottawa
OK I finally found a back seat for my car going to pick it up this week.
The back of my plymouth was finished with carpet and no seats, can some one explain to me how the back seat goes in, does it hook in? bolt in ? cause I cant see anything??
Also where could I find Seat belts and seat belt anchors?
Where can I find a light blue vinyl back seat cover?
thanks
originally there were 2 hooks at the top by the package tray along with 2 tabs on the bottom near the wheel houses! They were probably removed when they carpeted the area! No idea on the seat cover! E-bay one place to look for the bolts.
Kyle,
The seat back has 2 'hook' brackets on the top rear that slip into 2 slots on the cross brace at the package tray front. At the bottom of the seat back there are 2 straps that you attach with screws to corresponding brackets that are welded to the floor pan. Some cars have metal tabs that secure the bottom of the seat back. Pretty evident when you place the seat back into place. Once the back is installed, you place the seat bottom where it goes and simultaneously slightly lift up the front while pushing back on the seat, then push down on the front of the seat. There are 2 hooks that the seat bottom frame catches on. That's it.
As far as seatbelts and parts, if you're not into factory original, this is where I got mine. Good quality and prices: www.seatbeltstore.com
Try to obtain a factory service manual for your car. It'll help a bunch. Good luck.
I assumed thats how they went on, thanks for the info, if any one could snap a pic it would be really helpful
try Pro Fit upholstery for your seat covers I ordered mine from them for my 65 satellite complete interiorplus a 65 fury conv.and a 70 super bee her name is Libby Cheek and the phone # is 256-835-7107 good prices and quality.
Rear seat brackets
thanks
Here are a couple pictures that may help.
Jeff
thanks for the replys. Now I have another question Im trying to get the rear seat recovered and the cheapest I got quoted was 1000CAD which seems like alot is there an off the shelf cover that I COULD GET TO MATCH THE FRONT and are the front oem if not ??IMG_0364.jpgIMG_0365.jpgIMG_0366.jpg
does anyone have any ideas how I could attach the seats with out those clips ?
Can you see where they were before someone removed them? If so, get a set of brackets from one of the Mopar wrecking yards and weld or bolt them in:
www.wildcatmopars.com
