power loss
mrmopar
10:50 PM
Loganville Ga.
I've lost power between the ignition switch and the battery?? One minute it was cranking and then not so much? It does nothing when I turn the switch.This is on the 1968..Help
check fusable link at bulkhead, then if thats not it...trace the wire on the bulkhead into the dash were it go's to the alt gauge.
Before you do any of that, pull both battery cables and clean the posts and ALL FOUR ends of the cables.
