Charger686970
My 383 for my 68 charger has a comp hyd. roller cam and lifters. About four hours on the fresh motor the lifters crapped out, The engine builder sent them back to Comp and they sent a new set, they would not give him a reason as to why they failed they just kept saying we will send another set ever time he asked. The new set of lifters are in but I have not set the pre-load, I have the rockers backed off for now. I was thinking of getting a set of lifters from Hughes and I have the dimension of their lifters and was wondering if anyone could tell me how close dimension wise the Comp lifters are to Hughes lifter dimensions? Wanted to know if I could put Hughes lifters on the comp camshaft and still be able to run my current pushrods or are the dimensions different and will I need another set of pushrods if I go that route. I just do not have confidence in the replacement set of lifters from comp. I already spoke with Hughes and they said I can run their lifters on the comp camshaft but they said check the dimensions of the comp lifters to see about if I need to change pushrods and I can not find any dimensions for comp. Thanks for any info.
