You could run them out the bottom of the rear quarters behind the tires in a body panel flush set of exits shaped however you like.
I'd like to do that in front of the rear tires but the leafs are in the way, not sure I'd like it behind the tires?
If you're gonna do stacks, they HAVE to come up through the hood! :grin: Another option might be 1960's style NASCAR side exhaust where it comes out through the rocker panels just ahead of the rear wheel openings...
I really like the Nascar look but like I mentioned, leafs are in the way.
**cough 4 link cough**
I had a similar idea. My trunk and quarters are completely apart, and even with leaves mounted in the factory position, there would be enough room to run a 3" oval tube over the rear part of the leaf, and then through the trunk extension for a through-quarter exhaust. It's tight, though.
Cutting a hole on that paint would be quite a commitment.
David
This hobby is like my Jeep one "Just Empty Every Pocket "
Already did, it's where the reverse lights are.
Alread done I guess from the sounds of your last post
Anyway here's an idea;
Hide them up & behind the real valance {where you can't se them, if there's enough room}
& use turndowns to direct the exhaust down & out, just above the rear valance lower body lines...
You wont see anything that way...
Makes for a clean look too...
Just an idea, thinking out loud...
I've done that on a few cars, sorry I don't have any photos either...
or a Boat
Break out another thousand
As the pipe is running under the car, you make a 45* bend aiming for an area that's about 1/2 way between the wheel well and the door jamb. It ends up going past the rear frame kickup which is well ahead of the spring mount. You can oval the pipe and just have it stop flush with the body or modify the floor to raise the pipe up higher and then cut the rocker area into a half moon at the pipe exlt. Heck, you can even make the rocker exit totally encapsulate the pipe if you feel industrious. There's all kinds of ways to do an exhaust pipe exit without the springs getting in the way.... https://www.google.com/?gws_rd=ssl#q=1963+nascar+exhaust+outletI really like the Nascar look but like I mentioned, leafs are in the way.
Mufflers?? Who needs mufflers!? :grin: Have you ever looked at these? A simpler version can be made too. http://www.classicchambered.com/classic/products.html
There's some oval exhaust tubing & transition to round peices available too,
good for tight &/or narrow areas, not cheap but useful if you need it...
I can't remember {brain fart} where I got them now,
I think this was them, SpinTechMufflers
http://www.spintechmufflers.com/oval-tubing/straight-lengths/cat_42.html
It may have been from these guys too Burns Stainless LLC
http://www.burnsstainless.com/304ovalsstubing.aspx
