FOR SALE Engines and transmissions F/S
Moparguy1
4:30 PM
West Virginia
I have several engines and transmissions that I am not going to use for awhile and thought I would see if there was anyone that was interested in them. I will not ship these so you will need to be able to drive to me and pick them up.
77 440 without cam, I bought this engine like this and I don't know anything about it. I was told that it had been rebuilt but I don't know for sure. I have not had the heads or oil pan off the engine to look inside. The heads are 346's. I will take $500 for it. We can pull the heads off of it when you come to look at it if you would like to. ImageUploadedByTapatalk1447858724.807293.jpgImageUploadedByTapatalk1447858738.873209.jpgImageUploadedByTapatalk1447858748.123564.jpg
68 383 short block without oil pan. I am sure this will need to be bored. It looks to be stock bore. $300. ImageUploadedByTapatalk1447858838.207222.jpgImageUploadedByTapatalk1447858853.658132.jpg
69 318 engine. I have had this engine in several cars and trucks and always ran great. It was rebuilt years ago but I don't remember what was done to it. It has not been started in several years. $300ImageUploadedByTapatalk1447859002.439955.jpgImageUploadedByTapatalk1447859016.789725.jpgImageUploadedByTapatalk1447859027.241383.jpg
72 440 with 727 transmission. Engine had less than 100K miles on it and ran good when pulled several years ago. $1000.00ImageUploadedByTapatalk1447859365.207614.jpgImageUploadedByTapatalk1447859373.774458.jpgImageUploadedByTapatalk1447859381.775955.jpg
73 400 with 727 transmission. Ran good when pulled several years ago. $500
72 413 short block. Engine was pulled from a motor home with 18K miles. I pulled the large heads off and junked them and the engine has been sitting on stand ever since. $500
74 360 out of Dart Sport. Block has been bored 30 over and honed. I have the stock Pistons, rods, crank and heads that will go with the block. $600 I have a set of X heads that I might sell with this for the right money if someone is interested also. The heads have been redone but the guy did not install new valve guides like he said he did so it will need valve guides and a valve job. Has new stainless valves.
I also have a few big block and small block transmissions that were all good when removed. $300 each.
All these engine are stored inside and have never been stored outside since they were removed from cars.
I have a couple but I'm not sure what they are from. I can post the numbers on them tomorrow and you can see if they will work. I know the 18 spline Hemi 4-speed I have but I don't know if you want to spend that munch. I am asking $900 for that one.
Here are the numbers that I found on the transmissions, I'm not sure what they mean though.
C-99129
C-99128-3 on tailshaft
C-96561-H
96707 on tailshaft
I also found S 1 X 9
Maybe someone can tell us what these will work in.
Update on 77 440. I took it apart and it seems to be a standard bore but it has new bearings in it. The assembly lube that was used had dried up and wouldn't let the motor spin freely. It all appears to be in good shape but I am not reassembling the engine at this time. Chances are it will need to be bored because I am sure the cylinders are egg shaped.
C-99129
C-96561-H
96707 on tailshaft
Update:
The tailshaft number one the first transmission is C-99126 NOT 99128 so I think it is from an A-body. Sorry for the concussion.
The 4-speed transmissions have been sold but the engines and automatic transmissions are still available.
