- 11:58 PM
- Oct 16, 2014
- Salisbury, Vermont
Okay, bear with me for a minute. This will sound weird. For those of us who like to re engineer stuff, for various reasons, we often try to make a 40 + year old system work with todays more reliable and way cheaper parts. So I was sitting here in front of the fireplace thinking about 1966 Charger hideaway headlight buckets and the archaic method of their operation. I occurred to me that I might be smart enough to re engineer this system to my benefit. I propose to use a new power window motor to drive a gear reduction that moves a gear welded to a crossbar that is fastened to the inside end of each bucket. This will turn both buckets at the same time and rate as they open and close. The system relies on limit switches to stop the motor when the window( buckets) reach the fully open/closed position. The worm gear teeth on the motor can not be "driven" by the other toothed gear due to angle. So they reach the desired position and stop and stay. All I would need inside the car is a rocker window switch on the door or console with a one touch feature to operate in either direction. The buckets being fastened together insures that they remain lined up. I can get window motors out of doors in the local salvage yard all day long for less than $ 20 bucks. Since the motor is not "lifting" anything and is instead rotating a balanced unit there is almost no load on the motor and it should last a long time.
What say you?
What say you?
