Fuel Tank Sending Unit 1970 Hemi Roadrunner
Hemibird
6:33 AM
Connecticut
It appears, after some time diagnosing everything else, I need a new Gas Tank Float assembly for the 1970 Roadrunner - 426 hemi
The fuel line connections for sending units come in 3 sizes ... 3/8, 1/2 & 5/16. Logic would dictate it's probably the 1/2", but has anyone replaced one and know for sure (Before I start crawling around under the car)?
Also, can it be removed without dropping the tank? I'm tired of the gauge showing 1/2 tank when full and empty with 10-12 gallons left, and I may sell the car soon, so it needs to be fixed.
Thanks in advance
I believe the Hemi came with the 1/2" fuel line. My six barrel has 3/8" on it. You can change the unit without dropping the tank.
Chuck
Chuck
Really .... 3/8 on a 6Pak??? I just edited my post. I meant to say 1/2". Not sure what I was thinking at 2:00AM(Ish). I've resigned myself to the idea that I have to go under and measure it ... just to be sure.
1/2" fuel lines from the factory? No. Hemi and 440 six-packs had 3/8" fuel lines originally, all other engine combos had 5/16" lines.
Might just measure your body fuel line...that will tell you what size you need.
Under the hood, before the fuel pump.
This is correct, Hemi and Six Pack also had a return line to the tank
Everyone I know that owns a late 60's early 70's Mopar has had problems with the fuel gauge not showing the correct level......have to bend the float arm a bit to get it to show "near" correct......the Hemi cars (do not quote me in this) use the 5/16's line I think....they use more fuel mostly the ones with dual quads.
