Remove speaker grill from dash of '63 plymouth
MyStarCCar
5:20 PM
Alberta
Is there any trick to remove the front speaker grill from the dash of a '63 Plymouth? I don't want to force it out.
Aloha, No trick. Just unbolt the dash through the glove box then unscrew the grill. it was easy on my 63 Sport fury even though I had a AC box and vacuum lines in the way .
do you mean unbolt the dash pad cushion, take it off then access it that way?
Here is a pic of the back of the grille.Both tabs press outwards.
I'd reach in behind and pinch them together and carefully push out.
Go careful as they are old & brittle.
Good luck.
That's what I thought,been a long time since I removed it.
