- 10:11 AM
- Dec 4, 2009
- Pasadena, Texas
I know cars are better now a days than in years past. Our Durango is over 16 and my 'yard cart' Dakota is 21+ and the 2500 is 18. They are all original. The Dakota is original down to the hoses....except for the starter and water pump. Only the 2500 has over 100k miles on it with the others right at 100k miles.
It would probably be easier to list the lemons that were produced lol. I do know the Chevy engines of the 60's were produced with fairly 'soft' cast iron. You can even hear the sound of the cutter when you are boring one vs a Mopar or even a Ford block. Another thing I noticed when boring a Ford was the intermittent sound the cutter made. The material was not consistent at all and HAD to be honed. Granted, they should all be honed and you have to with moly rings but if you know what you are doing, you can finish tool a good finish without having to hone if you are using cast rings on a basic rebuild and it will last a long time. The Chevy stuff was much easier to do this on with a Mopar block being a bit too hard to finish tool. I was amazed at how quiet the sound was when cutting the Chevy stuff lol. As a machinist, we call soft cast iron peanut butter
It's easy to cut and easy on tooling and even the dust it creates is at a minimum.
