mopar 3 B
Sounds like the float seats are not closing causing carb flooding. May have pickup up something. You need to check float levels and jetting anyway. Even with 2.94 gears there is no excuse for engine bogging.
Do you have known good tune up items in this engine? Cap, rotor, fuel filters, plug wires, the CORRECT spark plugs? Gapped accordingly etc etc?
Yes, I was meaning the (2) idle mix screws and not the (1) idle speed screw, or at least that is what I think they are referred as... I was also told that one was adjusting air and one was adjusting fuel, which I don't believe is anywhere near accurate, but I let them go on...
Man...and I thought my thinking was dangerous! Just to clear things in your head, think of a four barrel as two carbs built side by side. Though each side has a primary bore, and a secondary bore, each 'side' basicly separate from the other.
The 2 mixture screws set the air/fuel mix...one for each side...each screw adjusting that 'side's' fuel to air.
That's why together, they should be 'balanced', or adjusted the same.
Once you get a good adjustment on mixture screws, a good idea to...gently turn the screw in, counting turns exactly, only seating the screw lightly when it bottoms. Write down the number of turns, and keep that number for reference. With that info, if things go wrong, you'll know where to re-set the mixture screws.
Why are you trying to go lean on the mix? You can hurt the motor with a too lean mix. There's a short range of 'peak' on mixture, one side lean, other rich. Should find the middle of that range, then slightly rich, not past peak.
But, you could be running into other issues on the motor, such as worn timing chain, that don't help. You had it running fair at one point, and possible to get back to it, but, motors like things right, before their gonna act right.
Cobwebs!:evil7:
I'm pretty sure you have some garbage floating around in your fuel system wit your latest post and issue. Hammer that out first. I agree on the needle and seat probably got some doo doo in them.
Now that I'm done laughing on the cobweb bit...
I'd have to look in the book, but pretty sure 4-5psi is about right on fuel pressure. Yes, it does matter.
Other thing is, at least your willing to learn! I'll toss in, that even knowing things, doesn't matter. It takes a knack to 'teach' someone how to understand, and do things on a motor. For many, it's much easier just to do it, than explain 'how' to do it. Just second nature. Main thing is...there are plenty of folks HERE, that are glad to help.
The carb...pay full attention to what's involved in pulling the top. Some parts need to be pulled, some will come out as you pull the top. To set the floats, you need to be able (for one setting) to hold it up-side-down.
That carb was new? Assuming you have a fuel filter...check, or change it. Far as the carb float settings, if you feel easy doing it, pull the top. Make SURE no trash is in the bowls, in the carb base. With the top in your hand, use a carb cleaner spray to flush the needle/seat of each float. Look at the type of floats in the carb...the good ones are brass, other kind are black. If it has the black type, they can get fuel soaked, making them heavier and won't float right, not letting the seats to close. If brass, check to see if any fuel is inside the float...that does the same thing as the black ones.
If the floats are good, then check BOTH up and down adjustments for the floats, adjust as needed, and slap it back together.
Update for the evening. I tore down the carb and verified floats were 7/16" & 15/16". There were the brass floats and didn't seem to have any gas inside. There was some junk in the bowl, so cleaned it out really well and cleaned the jets with some good sprays of carb cleaner. According to the Edelbrock literature, the stock jets are 0.095 and the metering rods are 0.068x0.047 (verified the number stamped on it was 6347), with the orange (5" Hg) metering rod springs (not sure what the 5" means...yet...). Cleaned everything up really well, reassembled and it started right up. I put the accelerator pump rod in the top hole, as that did seem to help things on the last drive till the dirt came into play. Does this change effect fuel flow through out acceleration, or just for that initial demand when hitting the throttle?
Idle was pretty good. A little rough till it warmed up, but was still running at roughly 700rpm. It does jump a bit, maybe 50-75rpm and usually down from the smooth idle. Same thing at 1000 rpm.
Decided to check timing, and was surprised to see it was reading ~34*(vac advance was disconnected, and manifold vac back to steady 19"). I had it set to ~11* initial before the flooding issue yesterday. Mech advance is 24* total with the Pertronix light springs to set the curve to 1k-2500 all in, so at idle of 700, it should not be in yet. Seems like maybe the distributor mech advance could be stuck. I might not have gotten everything back together well when I was hoping to check the timing chain slop yesterday and removed the cap, but I did give it a good wiggle when putting the cap back on. Have to check that again tomorrow.
So, some good progress, but also some loss of ground with the timing... Hopefully (and most likey) just something stupid I have done. Still have to get to town to get some big sockets. If any of you have an idea as to the crank bolt size on the 383, it might save me having to buy the whole set... Those big ones can be a bit pricey.
As far as the timing chain goes, if t is found t be sloppy and needing replacement, and knowing that I am new to motor work, is that something I should even attempt in my garage? If not, what should one expect to pay a reputable mechanic to do the job? I see that the chain and sprocket sets are not overly expensive, but it will probably be the labor to remove all the stuff from the front of the motor. And if I already have the stuff off, given that it has 104k miles, should I just go ahead and replace the water pump, fuel pump, thermostat and gaskets and belts?
Acc pump just for first shot of gas when throttle opens so engine doesnt go lean. Crank bolt should be 1 1/4", maybe 1 1/8". If it is not flooding or running rich, you dont need a regulator.
Probably be best to do the timing chain yourself as it's not difficult, all detailed in the manual. Just remove the radiator for space and start removing accessories. Ask a friend for help if you get stuck.
Probably don't want to hear this, even if you already know. 104K miles is bumping toward the high side. Timing chain is a fairly easy fix. One real simple way to check it is...if you have a timing light. Hook the light up, and check the timing. If at idle, the timing mark 'floats', or moves around, instead of staying steady, needs a chain.
Though with that mileage, probably looking at valve guide seals, the guides themselves, valves, piston rings...should I go on? Hard to say how many more miles you might get on it. Depends on condition of the motor, such as compression, and such. But, that's your call. Easier to learn on a motor with time on it, since you can't hurt things that much, over a fresh one. That's my take on it.
On the 5" Hg thing, I 'think' it means it takes 5" Hg to over-ride those springs, to pull on the rods.
the 5" refers to the spring compressing at 5"hg manifold vacuum or higher and pulling the metering rod down into the jet for lean cruise. anything under 5"hg will let the rod raise up for power enrichment. with high manifold vacuum you can try a 7"hg spring but make sure idling in gear is around 10"hg or more.
changing the chain isn't too difficult. you just have make sure everything is realigned correctly and you get a good seal at the timing cover/pan area. if the engine has a "silent" chain it's probably long overdue for change.
Aeon -I noticed you upgraded from a 2 barrel setup to a 4 barrel set up and no one else asked how you setup your kickdown since the geometry from your 2 barrel KD and 4 barrel KD are not compatible. Granted this wont affect your bogging issues but can make the car feel more sluggish and make it difficult to get a proper carb tune that works througout the power band.
with as much vacuum as you have i'd try heavier step-up springs.
