Front end rebuild
Northeast300
10:49 PM
Massachusetts
So my winter project is to rebuilding the front end of my 1970 300! I have sway bar bushings already but I am looking to see what anyone would suggest to use for tie rods and other front end/steering components.
I have everything BRAND NEW ---- Upper & Lower Ball Joints, Upper & Lower Control Arm Bushings, that's your suspension;
---- Inner & Outer Tie Rods & Sleeves, Idler Arm & PITMAN ARM ; that's your steering;
---- and the Inner & Outer Sway Bar Frame Bushings and Strut Rod Bushings; that's the rest;
Those three sub components comprise the entire front end
I also have a (one-shot) deal on MONROE Rear AIR SHOX -- if you like ..... some love, others loathe....
Good friends with Jamie Hyde, you may know him -- big in the 300 Club.....(he and his club mates get everything from me!!!)
Call me -- Craig -- [NO PHONE NUMBERS IN POSTS PLEASE] .... New York....
Call me -- Craig -- .... New York....
Thanks Craig, it may be a few weeks but I will definitely be calling you!
Don't forget to check the rubber K frame to body and torsion bar bushings while you got it apart.
I could have mention two "auxiliaries" to the front end --
I have the caster and camber / alignment kits that bolt onto the upper control arms &
I have the torsion bar boots & clips....
Call me when you're ready, have a Happy Holidays!!!!
Does the caster/camber kit have the parts that are needed to increase the positive caster? I think they are offset bushings?
Craig, can you PM me with your phone number please?
FYI,,For my 79 I got from Summit the Poly Prothane Body to frame bushings PTP-4-101-BL and T-Bar bushings to body PTP-4-106-BL.Both kits for $83 total. Was going to get the Firm Feel Aluminum kits but didn't want to spend the $400+.
Changing mine out because can't keep the T-bar height set.Changes everytime I drive the darn thing..
