Dibbons
- 1:02 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
Took many days with break free rust spray to remove the side window track screws. Now we find two styles of gasket/washers were used at the factory to protect the holes in the glass where the screws pass through. On the washer side, is a plain rubber like gasket, on the screw side is a rubber like gasket with a built in cylinder-shaped spacer the same thickness as the glass. I assume these gaskets are no longer available. At least I haven't seen them anywhere (unless these are stocked at glass shops perhaps?). Anyway, how does everyone else put these windows back together when the factory gasket/washers disintegrate upon disassembly? Thank you.
