FOR SALE parting Out '68 and '69 B-Body Steering Column Parts
rakort
5:45 PM
Wisconsin
Feedback: +3 / =0 / -0
Steering column parts .... from '68 and 69 GTX
I'll get up descriptions and prices shortly, meanwhile let me know what you need
thanks
Brian
20160227_114649.jpg20160227_114653.jpg20160227_114657.jpg20160227_114659.jpg20160227_114705.jpg20160227_114708.jpg20160227_114712.jpg20160227_114715.jpg20160227_114718.jpg20160227_114723.jpg20160227_114731.jpg20160227_114738.jpg20160227_114742.jpg20160227_114748.jpg20160227_114752.jpg20160227_114755.jpg20160227_114758.jpg20160227_114802.jpg20160227_114806.jpg20160227_114847.jpg20160227_115239.jpg20160227_115245.jpg
Hi i need the shift lever roll pin and spring, and lock washer. How much for it? Thanks phil
HI I NEED THE SHIELD AND SCREWS IN PICTURE 6 AND THE REVERSE SW IN PICTURE 12, SO IF YOU CAN GIVE ME A PRICE FOR ALL WITH SHIPPING TO 78414
Hey Rakort, I need the little plastic clips that clip on to the expanded metal part of the outer metal column. Uses 3 . I'll take three if ya got em. PM sent.
Sorry, those pieces are gone, only had two to begin with.
is the bolt with the large toothed washer going into the cage nut still available? If so, please PM.
I need non-column covers, so without the column shift and selector covers. I currently have a column shift and want console/4speed column covers. Let me know if you have them.
Thanks!
Please list prices as per rules....thanks.
Pricing, hopefully I have the picture numbers correct.
Brian
#1 – Lower portion of the column tube for a floor shift / 4-speed. Could be used to convert you column shift outer tube to a floor shift style. It has been cut off of the expanded metal (according) section $30
#2 – Random lower bearing parts…the one on the right is all together, but the bearing is rough - $15
#3 – Bolts – SOLD
#4 – Turn Signal Switch Connector $10
#5 – Upper Bearing – Only thing here worthwhile is the rubber isolator / cushion - $10
#6 – Cover – Sold
#7 – Wave Washer / Adapter upper housing - $15
#8 – special bolts for upper housing - $10
#9 - Turn Signal Lever - $10
#10 – Spacers – SOLD
#11 – Upper Column Housing (2-pieces) with Shift Indicator and bearing retainer - $25
#12 – Switch – SOLD
#13 – Shift Indicator Light and Wire - $15
#14 – ‘68 and ’69 OEM Turn Signal Switches – Both Need Cancel Cams - $25 each
#15 – Lower Couple with old seal, seal retainer, two “shoes” and 2 Pins - $30
#16 – Shift Lever (spring and pin is sold) – Shift lever has been media blasted (not the plastic knob) and primed / painted - $25
#16 – Qty 2 Plastic Slides for Bracket – they are old and somewhat brittle, but they are original - $10
#17 – Horn Button Switch (broken), screws for mounting switch, horn trim / button adapter and bolt (for a ’69) - $15
#18 – Qty 4 bracket to column short bolts $10
#18 – Qty 2 bracket to dash frame OEM nuts (only two nuts left) - $10
#19 – Original Column Tube Covers, one from ’68, one from a ’69 - $10 each
#20 – Original steering wheel nut and washer - $10
#21 – Floor Plate – SOLD
#22 – Column to Dash Frame Bracket - $15
