Hey Rakort, I need the little plastic clips that clip on to the expanded metal part of the outer metal column. Uses 3 . I'll take three if ya got em. PM sent.
I need non-column covers, so without the column shift and selector covers. I currently have a column shift and want console/4speed column covers. Let me know if you have them.
Thanks!
Pricing, hopefully I have the picture numbers correct.
Thanks
Brian
#1 – Lower portion of the column tube for a floor shift / 4-speed. Could be used to convert you column shift outer tube to a floor shift style. It has been cut off of the expanded metal (according) section $30
#2 – Random lower bearing parts…the one on the right is all together, but the bearing is rough - $15
#3 – Bolts – SOLD
#4 – Turn Signal Switch Connector $10
#5 – Upper Bearing – Only thing here worthwhile is the rubber isolator / cushion - $10
#6 – Cover – Sold
#7 – Wave Washer / Adapter upper housing - $15
#8 – special bolts for upper housing - $10
#9 - Turn Signal Lever - $10
#10 – Spacers – SOLD
#11 – Upper Column Housing (2-pieces) with Shift Indicator and bearing retainer - $25
#12 – Switch – SOLD
#13 – Shift Indicator Light and Wire - $15
#14 – ‘68 and ’69 OEM Turn Signal Switches – Both Need Cancel Cams - $25 each
#15 – Lower Couple with old seal, seal retainer, two “shoes” and 2 Pins - $30
#16 – Shift Lever (spring and pin is sold) – Shift lever has been media blasted (not the plastic knob) and primed / painted - $25
#16 – Qty 2 Plastic Slides for Bracket – they are old and somewhat brittle, but they are original - $10
#17 – Horn Button Switch (broken), screws for mounting switch, horn trim / button adapter and bolt (for a ’69) - $15
#18 – Qty 4 bracket to column short bolts $10
#18 – Qty 2 bracket to dash frame OEM nuts (only two nuts left) - $10
#19 – Original Column Tube Covers, one from ’68, one from a ’69 - $10 each
#20 – Original steering wheel nut and washer - $10
#21 – Floor Plate – SOLD
#22 – Column to Dash Frame Bracket - $15
