Test_3 Speed Wiper Switch
vn800
9:32 AM
Austria
Servus
One examined perhaps once the 3Speed switch on function?
Or anyone who has a clue, how to do?
gruß+dank
Franz
This is how to to test your 2864014 three speed wiper switch. Hope this helps.
High Speed Position:
B to F1 (-28 Ohms {Resistance Through Switch Resistor})
A to F1 (-28 Ohms {Resistance Through Switch Resistor})
B to A (0 Ohms)
F2 to Chassis Ground (0 Ohms)
Medium Speed Position:
B to F1 (-10 Ohms {Resistance Only Through Dash Harness Brown* Wire via R1})
A to F1 (-10 Ohms {Resistance Only Through Dash Harness Brown* Wire via R1})
B to A (0 Ohms)
F2 to Chassis Ground 0 Ohms
Low Speed Position:
B to F1 (0 Ohms)
A to F1 (0 Ohms)
B to A (0 Ohms)
OFF position:
B to P (0 Ohms)
A to F2 (0 Ohms)
F1 to Chassis Ground (0 Ohms)
Internal Circuit Breaker:
B to B/U (Always 0 Ohms Regardless of Speed Selection or Off)
Jim
I think you said on the german forum your English is almost zero so I've tried to translate Jim's response for you using google
Dies ist , wie Sie Ihre 2864014 drei Geschwindigkeitswischerschalter zu testen. Hoffe das hilft.
High-Speed- Position:
B F1 (-28 Ohm { Widerstand durch den Schalter Widerstand } )
A bis F1 (-28 Ohm { Widerstand durch den Schalter Widerstand } )
B zu A (0 Ohm)
F2 Chassis Ground ( 0 Ohm)
Medium Speed ​​Position:
B F1 (-10 Ohm { Widerstand nur durch Dash Geschirr Braun * Draht über R1 } )
Von A bis F1 (-10 Ohm { Widerstand nur durch Dash Geschirr Braun * Draht über R1 } )
B zu A (0 Ohm)
F2 Chassis Masse 0 Ohm
Low-Speed- Position:
B F1 (0 Ohm)
Von A bis F1 (0 Ohm)
B zu A (0 Ohm)
OFF-Position :
B bis P (0 Ohm)
A bis F2 (0 Ohm)
F1 bis Gehäusemasse (0 Ohm)
Interne Circuit Breaker :
B to B / U ( Immer 0 Ohm unabhängig von der Geschwindigkeit Auswahl oder Aus)
Jim
Jim
hello
Don't I understand these 4 measurements?
How to measure?
Chassis ground, is that the housing of the switch.
Be made the measurements at the switch built in?
Must the switch with any what cable be connected to?
gruß
Franz
Have you tried an additional ground wire from the switch housing to the drivers door jamb to see if you're dealing with a ground issue to the switch?
Hello
How to measure?
gruß
Franz
Hello
How to measure?
gruß
Franz
:thinker:
That's using ohms with a multimeter to get those readings. Do your multimeters read in Ohms also? I would think so since it was discovered by a German physicist, Georg Simon Ohm? Not trying to be a wise acre here, just asking so I know if I can become friends with Google and see if there some kind of conversion?
Hallo
Yes, also ohms can measure.
Will let me do an electrician.
regards
franz
That resistance wire is in a bundle in your wiring harness. Thanks to Jim at JSRestorations for the photos and assist.
Thin solid conductor wire with brown jacket and white tracer
Hello
There must I see, if this cable is still present in my wiring harness?
Could I get these two plugs A and R connect directly?
The two are chart here in the wiring also directly connected?
Or use a 0,205 mm² (24 gauge) wire? And good?
http://www.mymopar.com/downloads/1969/69CoronetA.JPG
Found this here.
http://www.forbbodiesonly.com/moparforum/archive/index.php/t-83581.html
greeting + thanks
Franz
Hello
Found this here.
greeting + thanks
Franz
Hello Franz,
I have been working with Kim to try and help you. This is the actual specifications on the wire used between the (A) terminal and the (R) terminal.
The wire gauge is 24 AWG {American Wire Gauge} or .5106 mm.
The wire length from the (A) terminal to the (R) terminal is 44 1/2 inches or 1130.3 mm.
If your dash harness is missing this wiring, you could use this length of wire outside of your wiring harness and rolled into a round small circle and secured onto the outside of your dash harness.
I hope this is the information that you are requesting and is the solution you are looking for. Glad to help!
Jim
Hello Franz,
Jim
Hello Jim
Yes, thanks, I need exactly this information.
Will reports, when the new switch here.
greeting + thanks
Franz
Hello Franz,
Jim
Hello
Yes, thanks,helped.Wiper work again.
regards
Franz
