lxmodguy
Gen3 Hemi Guru
There's no reason you have to loose the Lopey idle with FI. Especially with a pro charger. Don't be fooled by people who tell you FI requires a smooth cam. On a turbo setup maybe, but what's good NA generally works well with a pro charger. Now when you add boost you don't wanna have a 108 las because you want to broaden the powerband not narrow it. Besides its not about lsa entirely, valve events give the cam its idle. On a boosted motor you don't want a ton of overlap. It bleeds off boost. Too many folks profess to know about cams. The right cam is one that's matched to your heads, functions in your desired rpm range, and is tailored to your cubic inches, power adder, stall, and intended use of the car.
