Post your 11 second combos
Thanks to all of you sharing your track secrets, and not so secrets!
That 72 Redbird is awesome!
Those cars look like fighter jets to me...
I am going to go back and try wade through all the info posted by all of you!
I don't want to say I'm surprised... But the friendliness here, and the help & suggestions, remind me of what fun I used to have at shows & races!
You all just may renew my faith in humanity!
I forgot to mention some things...I will go see if I can add to my last post.
Happy Monday!
Happy Monday!
Couldnt agree more. This is the anti-yellowbullet.
BINGO !!!
thank goodness too
Happy Monday!
1st time to the track with this car.
'63 Dodge 330, 3500 lbs.
505" 440 with Stealth heads.
10.5 CR on pump 91 gas
Very mild Howards hydraulic roller with .545 lift and 235 duration @.050
2800 stall converter
3.55 gears
Street car that I drive EVERYWHERE!
11.75 @117 first 1/4 mile pass. Bumped the 6k Rev limiter in 1st and 2nd.
3.55 gears
Pretty good numbers. What was your 60 ft.? I think the ET should be a little better with that mph.
1.78.
I tried launching at a little higher rpm instead of off idle and it spun to a 12.04. :(
Tires were at 20 psi. I can go down to 14 psi so that will be the next change. Probably bump the timing a little too..
3.55 gears
Very nice first outing with that cool 63 ! Ron
A little update.
The car ran 11.30 flat at 119 mph today.
This is leaving just off idle as it blew the tires off loading the converter at all.
Only the 2nd time out and picked up quite a bit!
Nice new low 330, with a 3.55:1 gear too IIRC
congrats, keep it up or "go low" is what I should say
Congrats on that great pass. What size tires are you running in the rear ? Ron
How tall are the 275/60/15's on your car ? Ron
