JimKueneman
Couple questions about the interior window trim.
1) I get the moulding that clip to the headliner around the window on the top and sides. On the bottom there is a fat rubber looking filler between the rear shelf and the window. Does this come out? I am working on removing the rear window.
BTW this appears to have been out before and there is so much goop oozing out it made the outer trim almost impossible to remove as it was glued in more than the clips were holding.
2) It appears that the headliner and the rear shelf are stitched together as a single unit. It that a true statement? I am restoring this car and the interior is like new so I want to disturb as little as possible on the interior. I need to remove the glass to fix the rust in the corners and replace a few rusted out trim clips.
Thanks,
Jim
Thanks,
Jim
