How do I remove Drums
project62
11:30 PM
Ohio
Okay I give up. Would someone please tell me how to remove the drums from my 8.75 so i can pull the axles. Thanks
If it's a '62 diff you're working on, it can be a pain. I used a pulley puller with extensions rigged onto it. Some heat and a few taps and the hubs popped right off. Then I had to press the drums off the hubs. Supposedly there is a tool for this procedure, but I made do with what I had.
would this work
That is what I used with extra lengths added in to make it wide enough. Then I wrapped a ratchet strap around everything to hold it together. Kind of a pain but it worked!
You would want to probably back off the brake shoe adjustment, if maybe drums are grooved.
LOL, actually the strap merely held it from falling off, not for pressure related tension. It came off very easily. A little heat from a small propane torch and a couple taps with a hammer. I was very surprised after hearing all the hype over how hard they are to remove.
gd, you had an easy one!
You could bend the center of the drum by grabbing it on the outside.
If that's all you have, it's worth a try but use common sense and caution.
I've seen the video already with the puller. The only problem i have is, 2 out of the 5 studs are broke off, and no they're not opposite each other all on same side. So would the puller still work?
You're in the same boat as the guy at the end of the vidio. He ended up breaking off one of the two remaining studs. Might try what gdrill did, by grabbing the outside?
Search on here for other threads on this topic. There is a post with a link for changing your drums to the newer pull off type.
What I would do ... Assuming you wont be reusing the drum you can just flush cut the remaining studs and knock/pull the drum off and out of the way. Drill the center of the studs like the Crankshaft Coalition site suggested and knock the broken studs out the the way. Install some new studs ... reattach the puller and try to pull the hub again. Good luck.
Read this! Twice. Especially about the studs you will have to replace. Dan's the man on these '62s
http://www.crankshaftcoalition.com/wiki/Mopar_Tapered_Axle_Rear_Brake_Conversion
Good news and bad news. First the good news. We got the drums off, axles pulled and the center section and during this process found out that we have a sure grip with 4.10 gears. Bad news is, the rounded part of housing I guess you could call it the pumpkin has a nice little hole in it from years of sitting in the back 40. Thinking about cutting that bowl out and maybe seeing if I can get new one made and weld it back in. Any thoughts?
