- 2:04 PM
- May 14, 2011
- On the Ridge, TN
I have a 440 magnum, pretty darn stock except for the Comp Cams Magnum 270 in it (which isn't a whole lot warmer than stock, either). A new Edelbrock AVS Thunder 650cfm sits on a stock 4barrel intake. Headers, 3" (yeah, car came with it, I don't care for it) duals thru knock-off Flowmaster looking mufflers.
Stock distributor (A-1 Cardone rebuilt unit, "new"), stock from the parts store replacement ECU.
(I have a new Mopar Performance dizzy and orange ECU sitting on the shelf)
New MSD Blaster II coil, new MSD spark plug wires, fresh Champion RJ12YC plugs.
The carb seems close now that I've gone through it with the tuning kit from Edelbrock (I jetted it identically to their 750cfm Thunder and used the "pink" springs, figured that'd be close), setting mixture screws for max vacuum. Idles around 800 or so.
Now going through tuning phase...
-Ok, factory manual says 5 degrees BTDC on initial timing (actually says 0TDC w/manual, but I ain't going there), vacuum line disconnected and plugged off.
I started out at about 11-12 BTDC, where the engine sounded "happiest".
-It then says to set total mechanical advance at 36 degrees BTDC @ 2000RPM.
Check, did that. Had to move the initial back a just a hair to around 10-11 degrees BTDC, which the car was fine with.
So far, so good....
-Finally, it says to plug up the vacuum advance and set total timing advance to 56 degrees BTDC @ up to 4000RPM.
Hey looky there, it's already there, no need to adjust anything.
Results:
-Starts easily and idles fine.
-With the vacuum advance disconnected and plugged, the engine happily and smoothly climbs to 5500 RPM, no drama whether a slow climb or an "all at once" flooring of the throttle. Great!
However...
-With the vacuum advance connected, it still climbs fine until you get up in the high 4000s. At that point, it will still go to 5500 but there are audible little pops heard like cylinders are being temporarily dropped and she shudders just a bit.
Am I doing this right? Do these results make sense?
I don't have a problem driving it with the vacuum advance disconnected if that's what it wants.
This is my street/weekend car, not going racing anytime soon.
So far, so good....
Results:
However...
