K-chaiActive MemberHow much boost are you going to run?
Do you plan on W/M injection?
Vehicle weight, rear gear ratio, give us some details and plenty of pics!
Hi thank you for your replyIf the CR is an ACTUAL 7.5:1, I would not increase it if the plan is to run 91 octane fuel without additives. If you have limited the boost to 5-7 lbs.( as verified with a boost gauge), the first thing to check is the carburetors (they do have 'boost' reference power valves, don't they?). By that I mean that you want to 'over jet' the carburetors so that you are on the rich side, and then work backwards from there going by spark plug coloring. It's very easy to lean out a blower motor and destroy pistons. A method to retard timing at higher RPM (several makers of these devices, depending on your ignition system) is also a prudent buy. If you're still looking for more power after all the tuning has been done correctly, you can always up the boost and mix in some race gas. Do you have access to a chassis dyno and a shop that knows how to tune?
What we think really is not important, because if we say to increase the boost and the crank, rods and pistons don't like it, it's a very expensive lesson as they come flying out of the pan in several pieces. I asked you if your friend has access to a chassis dyno. Does he? Blown motors need to be tuned from way rich backwards to a little rich in small increments by someone with experience and the tools to analyze problems before they become catastrophic. Guessing wrong will cost your friend a lot of money. Find a dyno and a competent operator. That's the best advice I can give
Thank so much for your helpWhat we think really is not important, because if we say to increase the boost and the crank, rods and pistons don't like it, it's a very expensive lesson as they come flying out of the pan in several pieces. I asked you if your friend has access to a chassis dyno. Does he? Blown motors need to be tuned from way rich backwards to a little rich in small increments by someone with experience and the tools to analyze problems before they become catastrophic. Guessing wrong will cost your friend a lot of money. Find a dyno and a competent operator. That's the best advice I can give you...
Will 91 able tu run 11-1? Or methI myself might have kept the 11-1,ditched the carbs,picked up a bird catcher system,15% over,lock the ignition @32° and a fuel cell full of methanol. Start calling myself torett.......lol.
