440 + Transmission Lift Points
DMateya
4:45 PM
Pittsburgh, PA
Hello.
I wanted to verify what the best lift points are for my 440 motor with transmission attached.
I have the lift and a leveler.
Any advice on which lift points and what bolt sizes to use would be great.
Thank you,
Drew
If I can't catch one corner each on the heads, The 1st and last intake bolt on both sides works too. 3/8" coarse with at least 3/4" of thread engagement into the heads. Also, put flat washers under the bolt heads. Be mindful of what the chain is up against when you get tension on it.
