1969 belvedere pop out windows
69_ply
4:54 PM
Alberta
I am trying to reassemble the trim and pop out windows, but am unsure of the order of assembly. Does the upper stainless piece install before the rear drip rail corner or after, neither way looks correct when held in place. I did not disassemble this car and cant find any reference photos, any help would be appreciated. Hope this picture makes sense.
My car has vents but it has trim that runs down on top of the door. I would go trim under then drip moulding last.
Thanks for the info, I realize it is slightly different but would you be able to take a close up picture of that area.
Ah man I would, but my bird has flown the coop! Haha, it's out being painted right now.
Never took mine apart but here it is assembled on a post car from the outside. Can take more with window open if you need
Same as mine tempest. I don't know about you, but Inhardly see any post cars with that trim package!
Yea, I guess my car was a replica spring special. All the codes for the trim yet no A14 code...
Thanks so much, would you be able to take the same picture bu at an up angle, just above the window and below the drip rail is another piece of stainless that terminates at the corner piece. Trying to figure out how it all fits together. From the little bit i can see your car looks very nice. Thanks again
