WINDOW RUNS FOR 66 CHARGER
relam
2:34 AM
Chino Hills
NOT SURE IF THAT IS THE SPECIFIC NAME BUT THATS WHAT MY SHOP MANUAL CALLED THEM.
HAVING A HARD TIME FINDING THESE, THEY RUN THE VERTICAL ON THE DOOR AND QUARTER PANEL WINDOWS IN THE REAR LOOKS LIKE FELT ON THE INSIDE WITH CHROME TRIM ON THE EXTERIOR THEY WOULD COME TOGETHER WHEN THE WINDOWS ARE ROLLED UP.
SORRY FOR THE LOUSY DESCRIPTION FOLKS
ANY IDEAS FOR A SOURCE TO FIND THESE WOULD BE MUCH APPRECIATED
STRUCK OUT WITH ALL THE MAJOR SUPPLIERS.
Are these at the rear of the glass? If so, go to justmopar.com. They have a wide variety of rubber and window channel material at decent prices..
Jeff
Jeff
Hey Thanks Jeff, I will check them out !
Sorry for the bad lead. These are listed under Coronet:
https://www.metrommp.com/?f=detail&ModelNumber=VS 7-A&VehicleYear=1967&Make=DODGE&Model=CORONET
I wonder if your quarter glass has the same front chrome trim (since the door glass should be the same between Coronet and Charger) if these would work? They should slide down into the chrome trim. There is a flocked version too.
I SPOKE TO METROMMP LOOKS LIKE YOUR CORNET HS A CONNECTING CHANNEL SIMILAR TO THE CHARGER. THEY DO NOT SELL THE CHROME TRIM THAT I NEED FOR THE WINDOW BUT THEY DO OFFER THE FELT INSERT.
BIG THANKS, RELAM
WOW
Isn't that something. I will pursue that Thank you
So here is an FYI in my desperate search I found 3 Mopar yards around the country, and I mean around the country.
I will send you their info, you may know of them already
Arizona, Bama, and Oregon. Oregon has 5 66 Chargers in her yard, Jackpot.
BTW it was your Metrommp that started the connection, BIG THANKS ! They do offer the felt inserts for the channel runners, bulk material.
