Great work and an awesome car you should be proud
When I drive my car I feel warm air blowing at my legs. Since none of my heater controls work (the linkages are missing) I assume that the heat is coming off of the engine and somehow entering the car. However, I'm wondering if it possible that the heater is working and somehow pumping out heat. Is there an effective way to cap all of that off?
Also, I could probably figure out a way to prop all of the vents open. Do you think that would draw in more warm air or give me some cool air? Keep in mind, my car came out of the factory with A/C and no longer has it so there are no vent doors in the kick panels which I can open up.
Yep, just did this myself. With headers and big-assed exhaust especially, a lot of heat comes into the cabin as it is and mine isn't a winter car anyways.Bypass the heater.....easy to change back.
Jeff
I'll second this. I'm VERY impressed with not only your fearlessness in tackling this at such a youthful/inexperienced age, but with your insistence on doing things right.Fantastic work your doing. I'm glad there's other young guys getting into the old mopars . And for a first timer wow you do very nice work. Keep it up and keep up the picture s
I capped off the heater core with some of those oversize vacuum port caps (1/2" in my case) and actually went as far as pulling the two heater pipe nipples out of the engine, plugging the threaded outlets with stainless 3/8" NPT plugs.
Probably would have been easier just to loop a hose between the outlets, but I went for the cleaner look of removing all of it.
