salty_eye9692
EDIT : I FOUND IT!!!! So based on comments apparently my car has the later 73 spindles. And I did order 73 challenger rotors. For some reason the challenger seal is too big to fit the spindle. So I found that the seal is a precision part number: 450076which has the outter ring 2.690 and the seal lip of 1.750. So I guess the answer is that the car was already converted.
I'm 26, been working on my first Mopar (1972 charger SE) for 8 years (takes a long time while learning and being super broke lol) got the front suspension together finally, after all new bushings, welding plates to the lower control arms, and new torsion bars etc. I have the new calipers and rotors ready to go; new races and bearings, used an "auto packer" to put grease in and filled the rotor cavity with grease to keep it from melting out of the bearings. I go to install the oil seal brand new from Timken. On both rotors the seal isn't a press fit inside the rotor bore. but it does slide onto the spindle and ride like it's supposed to. secondly there is no dust cap for the spindle nut ant lock for the front rotors. Thirdly I don't know think the brake hoses up front are the correct length. factory slide pin style calipers. car was originally a 318-slapstick car the rotors are a hair under 11 inches, so I think they are the 10.87 rotors. the oil seal I have is 1.75 by 2.375. inside bore for the dust cap is 1.790. Also, I have ZERO idea how the brake line routing goes since I bought the car as a decent rolling chassis. so, any pictures of the brake hose routing and brake line routing as well as the plumbing for the brake distribution would be VERY appreciated
TLDR What are the correct oil seals, dust cap, and front brake hoses for my car? And I need pictures of brake line routing and plumbing.
