So I got the cross member reworked last night. If you didn't know I stated earlier the new poly mount was .25 taller than OEM. So with the gear vender I needed that .25 back. I simply cut the bottom plate off and spaced it down. If your ever in a bind and need some brass for a backstop when welding, a old tip from your welder works great. Anyway. got it welded up and repainted and back in the car. Got the last of the linkage cleaned up and ready to install tonight. Slowly making progress.
