Need help converting to Holley linkage
CoronetDarter
10:17 PM
Lincoln, CA
Hello members - just finishing up swapping my Eddy carb for a FiTech EFI system. FiTech has a Holley type linkage; are brackets available to convert Eddy to Holley? It's a 440 with a 727 in a 69 Coronet.
Just talked to a Holley tech; narrowed down part # 20-7 for the throttle lever but doesn't address the kick-down.
Could go with Lokar kick down cable KD-2727HT combined with the 20-7 if a bracket isn't available.
You'll need Holley P/N 20-67
The Lokar setup is really nice, cleans things up, easier setup, more flexible to changes and moves more freely. I ran both cables when I still had a 727 in it and am still running the throttle cable. That's what I'd do.
So you ran the dual throttle/kickdown asembly? I saw the setup on Lokar's website; the bracket bolts to the rear carb attachment stud. And with the Lokar you don't need the throttle return spring?
Here's a few pics from the one I had, the bracket that attached to the tail housing is close to the floor but wasn't much trouble to get fitted up.
