Darthomas
Ignition switch new or old?
NewIgnition switch new or old?
I'll try the new blast n let you know what happensI hope it's not that everything on my car was new just 3 yrs ago
Just put a jumper across the ballast, if that allows it to keep running then it's the ballast.Could a bad balast cause t
I'll try a new blast tomarrow after work. Maybe the blast that I barrowed wasn't any good. They are cheap enough that I'll try a new one. But it still doesn't make sense to me that a new starter real can make it run
I finally got home and put the new balast the wires on. It was a no go. But when I wiggledUnseat and reattach the bulkhead connectors and try again, or just wiggle them with authority and try it.
I got home and put on the new balast, it was a no go. Then I wiggled the little pos wire that goes to the relay swicth along with the bulkhead connector it started and kept runningUnseat and reattach the bulkhead connectors and try again, or just wiggle them with authority and try it.
Thank you for your help everyoneI finally got home and put the new balast the wires on. It was a no go. But when I wiggled
Yes, there is a retainer clip on each side of each of the 3 pugs. The picture below shows the clips pretty clearly. A long thin screwdriver in the slot at the base of the clip will help to pop them loose.Will it actually unplug?
Should stop in the welcome wagon and introduce yourself.Where's yer manors?Hey guys, I'm new here but I have solved a few problems with my 1969 GTX by reading here. I recently retired, when I was a kid, I was a hot-rodder, but many years have passed since those days.
I am having this start then stop immediately problem. I am able to make the car start and run by "wiggling the bulkhead connector with authority..." That works for a start or two and then back to the same problem until I wiggle that connector again. What is the permanent fix for this? Is that connector replaceable? I have not been able to unplug and re-seat it, so I need some advice. Will it actually unplug?
Thanks in advance,
David
I had a similar problem, but just the opposite of yours. It would not start til I released the key. I knew it was with the ballast resistor bypass circuit. Long story short, I finally pulled the bulkhead connector and used a small screwdriver to just slightly bend the contacts on that wire for a more positive contact. Problem solved. Sounds like you MIGHT have the same problem, just on the run wire instead of the bypass wire. If that doesn't help, it might be the ignition switch. In my case, that tested good before I went to the bulkhead connector. Another possibility could be a bad ballast resistor.
