- 10:38 AM
- Dec 14, 2008
- Long Island,New York
3825. However add tubby and were at a line weight of 4100.
You a big boy!! Hammer down,,,,,
Mike did you get that link I sent you?I was just joking about the 7000 lb car....I know it only weighs 6000lbs.
Hows that trans coming?Mike did you get that link I sent you?
Well its going well pulled it out on tuesday and broke it down the only damage is the input shaft. I had never been inside the tranny so it was good to see what was in it. I dont know who built it but it has all good raceparts. and all in good shape but the shaft seemd to be stock so ordered one from A&A hope to get it this week. The converter seemed ok but, I sent it to Ultimate Converters for them to open it up and check it out as long as its out of the car. Its an 8" but thats all I know. We are going to make some improvements on the exterior better cooling line connections change to AN fittings. Thats about the extent of my knowledge on trannies anyway. I will keep posting as it goes along. Thanks for asking.Hows that trans coming?
Did it look sorta like this???Well its going well pulled it out on tuesday and broke it down the only damage is the input shaft. I had never been inside the tranny so it was good to see what was in it. I dont know who built it but it has all good raceparts. and all in good shape but the shaft seemd to be stock so ordered one from A&A hope to get it this week. The converter seemed ok but, I sent it to Ultimate Converters for them to open it up and check it out as long as its out of the car. Its an 8" but thats all I know. We are going to make some improvements on the exterior better cooling line connections change to AN fittings. Thats about the extent of my knowledge on trannies anyway. I will keep posting as it goes along. Thanks for asking.
yes
Absolutely..and I installed it....very coolMike did you get that link I sent you?
I have broken 2,,,,,,must be the luck of the Irish!Never broke one, or my son either. He's north of 825hp, I'm over 900hp. I've got 300 passes on mine.
That photo is before I put the anti roll bar in. Does not do that now.
Ran a new best of 10.71 @ 127. 1.49 69 foot. New converter picked it up 2/10ths. Car is working much better.
Dominator intake and carb next upgrade.
