miller
Looking for thoughts/opinions on my fit. How much would a minimum spline engagement be for a slip in yoke?
What I have is a 67 BB 727, 29/30 output shaft...hooking up to a 67 model 8 3/4" rear, with a 1330 yoke (what was on it), type that takes straps. Question on that shortly.
Had a driveshaft made locally, by a guy who has a good rep...okay. Gave him all needed info/measurements. Provided a new 29/30 7290 slip yoke, since I decided I wanted 7290 joints, using a combo 7290/1330 u-joint at the tail end. (IF I have to do anything on the axle down the road, I'll change out that yoke.)
Have to get where I can see straight again (hell, and only have one eye!!), but will look hard at the length deal, when I un-hook the tail end of the shaft. Just thinking maybe shaft is a little short.
Other thing I'm fighting is the blasted straps. Three sets now, last ordered online from where I bought the slip yoke. (Driveshaft outfit) Same strap kit part #, but photo showed dif strap #s.
All these strap kits are Spicer. Kit came in...same damn straps. Problem...they don't fit...bolt holes too far apart. Before you ask, yeah, positive rear yoke is a 1330.
Or, would I be better off DRILLING the threaded bolt holes out of the yoke, and put in u-bolts?
