Doug Larsson
- 12:19 PM
- Apr 18, 2016
if you know all that...spin the wheel and watch driveshaft rotation...one full rotation of the driveshaft...count how many times the rear wheel revolves....divide by 2 if non suregripIf it's a 489 case, we know it's an 8.75 axle. Whate we cannot tell by a picture of the back is what gears came with the car.
The question was what rear?If it's a 489 case, we know it's an 8.75 axle. Whate we cannot tell by a picture of the back is what gears came with the car.
Read againHe wants to know what gears...said it's a 489 case...8 3/4
You can purchase a suregrip for an 81/4, but if you plan on building that 400 you may want to go with a 8 3/4, its stronger (8 1/4 won't handle much power) and the parts cost about the same. Unless you wanna go digging at a junk yard for 8 1/4 equipped Dakota and yank the sure grip out. The only parts off the 8 1/4 that could be used on a 8 3/4 I believe are the drums. I don't think anything internal will interchange.So two ?'s then can you put a sure grip in a 8 1/4 and if not what can you use off of the 8 1/4 if you purchase a 8 3/4 ?
So doing one legged burn outs isn't a good idea huh lol.You can purchase a suregrip for an 81/4, but if you plan on building that 400 you may want to go with a 8 3/4, its stronger (8 1/4 won't handle much power) and the parts cost about the same. Unless you wanna go digging at a junk yard for 8 1/4 equipped Dakota and yank the sure grip out. The only parts off the 8 1/4 that could be used on a 8 3/4 I believe are the drums. I don't think anything internal will interchange.
So I guess I should quit doing this huh until I get a 8 3/4 ha ha.You can purchase a suregrip for an 81/4, but if you plan on building that 400 you may want to go with a 8 3/4, its stronger (8 1/4 won't handle much power) and the parts cost about the same. Unless you wanna go digging at a junk yard for 8 1/4 equipped Dakota and yank the sure grip out. The only parts off the 8 1/4 that could be used on a 8 3/4 I believe are the drums. I don't think anything internal will interchange.
