khryslerkid
- 7:09 PM
- Mar 10, 2010
- Hanover, Pennslyvania
Well I received the radiator from Engineered Cooling Products, part#2375s. Watched the UPS driver get off the truck with one in each hand!
Should have kept my mouth shut but that's not the way I was raised. I said I had only ordered one, and he replied with they were double shipping labels, take your pick. So I chose the box with less scuffing and he is sending the other one back.
Then I called Frank at ECP and told him what took place.
Not a bad looking radiator for the money, $250. including shipping. Fins are a little roughed up from shipping. Welds look good, heavy material used in the tanks. Not epoxied, inside the tanks are clean, free of slag ect. Top tank isn't perfectly square with the bottom but not noticeable. Bolts right up for the exception of the lower right bolt. Bracket is for the newer body, shorter but an easy fix. Fan shroud brackets are on the outer portion of the core, so no bolts or screws in the rods. Also it is one inch shorter than factory. I'll probably split the difference. All in all, its cheaper than a re-rod and the one I took out weighs about 80 lbs!
