May I ask what altitude you were at?
I believe around 700 ft!May I ask what altitude you were at?
yes it was better but humidity still was pretty highSo air was good this weekend! Not so much this coming weekend! I bet you'd lose at least a tenth with 90's....
12.00 second killer car....good jobView attachment 349882 View attachment 349883 Well I can finally post in this thread it may not be deep in the 11s but i will take it for a 4000# cast headed 440 manual trans car! also achieved a little air under the front tire!
65 Coronet 500
500ci
30 over 400 4.15 stroke
K1 rotating assy, wiesco pistons
11.3 comp
Lunati hyd roller
comp magnum rockers
trick flow 240pp heads
Doug headers. full 3" exhaust, dynamax ultra flow mufflers, tti tails
trick flow track heat manifold
fitech 1200 on e85
727, 3000 Hughes converter
strange dana 60 3.73
full load 3920lbs
best 11.48@118
pretty consistent 11.6@115 1.6-1.7 60'
Thanks been a task getting there and staying there.Very similar to my combo save for your compression is a point higher and it weighs a little more. I run 3.55 gears (soon to be 3.54).
Good job!
Tell me about it! I would love to see a 10.99 by years end but breakage last weekend and brutal heat have me sidelined.Thanks been a task getting there and staying there.
Lunati hyd rollerTell me about it! I would love to see a 10.99 by years end but breakage last weekend and brutal heat have me sidelined.
What are your cam specs?
Wow, very similar cam as well!Lunati hyd roller
20230713
243in/251ex@50
295/303
.560/.565@1.5
110 Lsa
106 CL
Track conditions really make the difference when your trying to get better times. They ran division7 the last three days here in Sonoma. I tried to go but the 92 temps kept me on 1320go. I can remember back and some nights were so cold we were all in our cars to stay warm. Mind you it wasn't July but, I have not seen any of that in a few years in November.Yesterday here in NE Ohio it was 94. They raced but the track was like grease. 145 deg
68 roadrunner
440 30 over
diamond flat top pistons
557 purple shaft flat tappet cam
custom crank
scat h beam rods
Mopar M1 intake
edelbrock performer rpm heads 75cc
1.6 Harland sharp Rockers
quick fuel 850 annular booster carb
hooker headers
built 727 transmission with trans brake
4.10 spooled 8 3/4 rear end
custom 3500 stall converter
everything caltracs for suspension
best ET so far 11.02 @ 123 mph
trying to get into the tens!! View attachment 350702
DOMINATORS RULE....67 Belvedere Wagon 3940 lbs(heavy pig, added a roll bar over the winter and 200lbs boy did that slow me down)
512
400 block, 440 Source 4.25 crank and I beam rods
Diamond flat tops, Eddy Performer Heads(84cc)
Comp ratio 11.6
M1 intake, 2" adapter and 1050 3 circuit Dominator
Comp Cams XS282S mechanical
I 244, E 252 @ .050
I .555, E .577(this is w/Harland Sharp 1.6 rockers)
19" mech fan, stock water pump,
TTI stepped headers and 3" exhaust that dumps by the rear wheels.
727, Griner RVB, PTC 4500 convertor, 4.10 gears, Caltrac springs and shocks.
Still tuning the Dominator, ran 11.28 at 117.37 and a 1.55 60' at Quaker City on 7/15/16. DA was 3098.91 w/7mph head wind. I shift at 5600 and cross the line at 6100. The carb is new and this was the 1st outing. Its lean in the top end. I started at 91 sq for jets. I didnt have 4 of ea jet that night so used what I had available. I bumped them up to 92/95 and picked up 1.5mph and .06. I have a better jet selection now as well as air bleeds and will keep playing. I think I have another 2-3mph I can get out of it w/more tuning. Right now timing is a conservative 34 total.
Yes the do Mike. I still have a lot of tuning needed. My et vs mph is about 50hp difference. The calculators have me around 550hp(flywheel) for et but only 499-501 based on mph for my weight. If this rain will ever stop I may be able to get back out and play with the air bleeds and jets some more.DOMINATORS RULE....
My Dominator install experience...as I have shared before:Yes the do Mike. I still have a lot of tuning needed. My et vs mph is about 50hp difference. The calculators have me around 550hp(flywheel) for et but only 499-501 based on mph for my weight. If this rain will ever stop I may be able to get back out and play with the air bleeds and jets some more.
