drobertson
So I'm gonna build a 440 soon. It's a 74' block bored .40 over. The bores are actually pretty good, so I'll probably just hone the block. I'm gonna get a new crankshaft from napa, and get a harmonic balancer and flexplate from them as well, depending on whether the crank I get happens to be a cast or forged one. I will be using the stock LY rods, with ARP bolts. Here is the real question... When choosing pistons, how important is it that I have the rotating assembly professionally balanced? I'm using a factory crank and rods, so can I just throw in some kb pistons and call it good https://www.summitracing.com/parts/uem-kb237-040/overview/make/dodge? I will be using the proper flexplate and balancer for the crankshaft. This engine will be in a 73 Charger, driven mostly on the streets, and occasionally at the local airport drag races. Thanks. -David.
