- 11:25 PM
- Aug 23, 2012
- Cornfield County SC
Need a lower passenger fender. I s this one any good?
Just saw this. I have to check and see if we want to take the column apart.I have a '65 Coronet & need signal light switch assembly & horn switch assembly that attaches to steering wheel & horn ring mounts to. I guess this would have same? Would you have & how much$? Thank You!!!
Both fenders are totally rotted out front and rear.Need a lower passenger fender. I s this one any good?
I will take a look. I doubt they will come apart. This car is pretty crusty underneath.I need the rear spring hangers if not rusted bad.
Throttle cable?The hood, front doors, underhood wiring, ignition switch, trunk lock, antenna mast and heater switch have been sold.
Good windshield and back glass still available. The instrument cluster and bezels are still available along with front fender moldings(very nice) and misc trim and small parts. The drivetrain is still available. I have a video with the engine running.
The Kframe? Yes I still have it. $125Still have the crossmember?
My 65 was originally a std trans. A stroke played havoc with my left side...so now going to an A/T. The small std shift pedal doesn't do it for the looks of the interior.
If you have the A/T brake pedal , I believe I just need to pedal-arm and the pedal it self which I believe is all one assembly . Thank you .
$25What are you asking for the pedal and where are you located ?
Thank you for the reply.
Hi, everything on BBody is pretty much on the "honor system" so I can send you a postal money order for $35 ( ?) for the metal pedal ( don't care about the rubber ) and shipping.$25
I'm near Harrisonburg, VA
