Solid k frame isolators
Not for sure what you are talking about?
On 73 and up cars, mopars had a new "torsion quiet ride system" which put rubber isolators between the k-member and body, and a rubber isolated rear end, and new "spool" style motor mounts. A popular upgrade for 73 and up mopars is to replace the rubber isolators with solid polyurethane or aluminum spacers. It improves handling.
Summit has them. Prothane,PTP-4-101 BL for the K frame.Also PTP-4-106 BL for the torsion bar mounts .Less than $100 for both kits together.
I use energy suspension ones just make sure you grease them good before installing them you'll rip your hair out if not
I should have first set done next weekend. Having to wait for an opening on a mill.
