66 coronet poly 318 taking her home
2:41 PM
ripplemead va
bought at estate sale 79000 documented by title miles
That's in terrific shape! How much did it set you back?
For that little money, you can't go wrong.it was an as is no reserve auction they didn't even start the cars.had to track down the daughter to get a power of attorney to get it titled . found out the car was a 1 owner old guy got new Nissan in 04 had the engine trans mission rear end and brakes rebuilt and put about 2000 miles om it since then
:thumbsup:
engine back togeather running dry rotted coopers replaced with new unroyal tiger paws rims painted my other winter project 67 dart
carpets installed seats back in now the dreaded part clean and inspect front suspension and underside will replace at least tie rod ends and ball joints what ive seen of the underside well coated with under coating thin down some black paint and make it black again
so after 2 hrs inspecting the bottom I have examined this car top to bottom and not found a pinhole of rust through a lot of factory paint on the bottom so will try to preserve it does need a tail pipe and maybe a rear end gasket
so I really don't like the dart so I may sell it or part it out and sell as a roller the dart has a 8 3/4 rear 3.91 sure grip newly rebuilt should I switch them out and start building a sleeperView attachment 363726
so the coronets all back togeather and running great pulled the engine and transmission out of 67 dart today going to sell it as a roller has a pristine rust&damage free body underside nicely detailed painted black newly rebuil 8 3/4 3.91 sure grip welded in frame connectors gas shock front discs new 2 1/2 inch mandrel bent exhaust system with flow master suspension in great shape great startin point to build any type 67 68 69 dart you want has clea
n va title in my name
front suspension seems very good drove about 100 miles probably in better condition than
you would of expected of a used 66 coronet in 69 or 70 growing to like the patina of the faded hood and trunk
That's the way I LOVE to find them.
