Mike Gaines
- 12:49 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
My engine builder told me today that he was making my new stroker motor a 505" not a 512". He only wants to bore it .030" over (505") not .060" over (512") so the cylinder walls will be just that much thicker. It is a 1977 Block.
I had him also install 440Source Steel Billet Main Caps and 440Source Steel Billet Girdle with studs. Block work will be finished in a day or two.
He is finishing up my heads also (INDY SEZ). He is using all COMP valve train components..dual valve spings, retainers, lash cap and locks. Using the INDY Valves and Viton valve seals.
He told me he didnt want to port the heads to MAX-WEDGE size as he believes the standard 440 size ports would give me more low end torque for my heavier (than an A Body) B Body Coronet.
I will keep you posted on the build.
He is going to video the Dyno Pulls.
