WTB NEED BADLY
DVO
4:25 PM
South Florida USA
I need a wiper drive link for a 78 Monaco, the one I have is all chewed up and the wiper arms don't move.
Any help finding one is greatly appreciated.
dvo
dvo
More Information for A-1 CARDONE 40382
1/3
Point to Zoom
Reman
  • Each unit is 100% computer tested at 3 points in the remanufacturing process for guaranteed performance.
  • Every motor is assembled with the precise amount of lubricant to ensure quiet operation and long life.
  • Improved over original performance - Mechanically anchored connectors by way of thru-hole soldering results in stronger, longer lasting electrical connections.
  • Motor magnets are 100% recharged for superior performance and reliability.
Wiper Motor Installation Guide
Troubleshooting:
Motor will not park, will not shut off, parks in middle of Windshield, or motor will not run.
Replacement wiper motor parks in wrong position.
Alternate/OEM Part Number(s): 3431533, 3431606, 3431608, 3431718, 3431790
A-1 CARDONE Warranty Information
Master Cylinders, Water Pumps, Steering Components, Hybrid Drive Batteries 3 Year / 36,000 miles. Ultra Calipers 10 year / 100,000 miles. Brake Calipers & Brackets 2 year / 24,000 miles. Brake Pads, Power Brake Units, ABS Components, Fuel/Air Systems, CV Axles & Propshafts, Electrical Motors, Electronics, Smog Pumps, Vacuum Pumps 1 year / 18,000 miles. Magna Pure Power Steering, Air Springs - Limited Lifetime. Engine oil and filter MUST be changed when replacing Turbochargers, Diesel Fuel Injection Pumps, and High Pressure Diesel Injection Oil Pumps. Refer to installation guide in box. Failure to follow voids warranty.
Warranty Details
The wiper motor works great, I need the link from the motor to the left side pivot. The nut came loose and the motor shaft end ate up the slotted opening on the drive link.
Weld a small hole washer onto the backside and file out the flats you need?
A picture of the end of the linkage and the damage would be helpful - might be very easy to weld in a patch as stated by DAKO . . .
